neutral at a switch
berlingo2
Mar 15, 2009
5
Hi Guys
Has anyone ever heard of having to use Porcelain connector bocks to terminate the neutrals at a light switch, Somebody told me the other day that you do. If so where would this be in the regs ?
Think they may be getting confused between 'light fittings' & 'light switches':|
some light fittings, e.g. certain bulkhead or enclosed bathroom lights can have a lot of heat from the bulb in close proximity to the connection terminals for the incoming cable.
If heat is an issue most plastic connector terminals would stand risk of melting. therefore porcelain are used..
RULE:
If porcelain are inside the light fitting DON'T swap them for plastic, even if you knacker a screw thread.. replace with proper porcelain connector.
BUT.. at a light switch... there aye no heat .....
(or extremely minimal! as we all know lectwick generates heat as it goes down cable:p)
unless you is using very strange switches? :eek: ? :|
So normal plastic with appropriate current rating are all OK,
i.e. best not using 3a rated block on a 6a rated circuit IMHO;)
so me thinks someone was talking about light fittings and Chinese whispers has made it light switches....
next person to pass it one will say light-houses must be made of porcelain o withstand sea water!Blushing:p:p:coat
HTH:D
Hi GuysHas anyone ever heard of having to use Porcelain connector bocks to terminate the neutrals at a light switch, Somebody told me the other day that you do. If so where would this be in the regs ?
the general fundamental principal is 134.1.4 pg 19
section 526 starting page 106 gives load of requirements for electrical connections..
the one about heat is 526.4
twould be somewhere in that lot if it existed IMHO? ?:| ;)
One of the things I was told on my first part p assessment was that if you use terminal blocks in switches they need to be affixed to the box otherwise they are not classed as mechanically sound. I personally use wagos or crimp connectors in switches as these are classed as mechanically sound. I must say I have used a lot of terminal blocks over the years with no problems but to comply I do use the latter method.
Batty
Hi, i was taught to use Bakelite type connectors at switches. These are nowadays replaced with the harder plastic types, not the cheap nylon ones. The reason was, the householder may swap the switch for a dimmer which will get hot. This in turn could melt the connector. Yep i agree its unlikly but its another 'good workmanship' thing, like earth leads in backboxs
Why ? BS pvc cable has a higher rated temp than non marked nylon connector blocks
Dont know , as i said i was taught it as being good workmanship and i guess its the OP answer.
Edit,
Also, most connector blocks now are rubbish, they have skimmed so much metal away they either split along the bottom or the thread strips. This doesnt seem to happen to the hard types
Dont know , as i said i was taught it as being good workmanship and i guess its the OP answer.Edit,
Agreed most material is made cheap and nasty nowa days
I must agree these connectors are easier i usualy teminate cable and heatshrink if normal cieling rose is being replaced with downlighters no prob with regs being unaccessable
Porcelain connectors at a switch, Sounds like someone is reading from a local council spec. probably Birmingham's. They used to specify wooden rawlplugs and round head black japanned screws to fix boxes and an earth wire to the metal sheathing , c/with crimp lug and self tapper to connect it. It is " Old School" as Daryl says, used to be for light fitts.
Deke
