Didn't do one on his device but when we asked why you haven't filled on in,miraculously he's got a paperwork one with figures close to the recall tech's results
Whats the justification for removing the rcds and fitting the mcb?
He Attended a neutral earth fault &couldn't be arsed to find it,just put a follow up back & that's how I found him out by the recall tech reporting it to meWhats the justification for removing the rcds and fitting the mcb?
So you know one of your colleagues is putting people at risk. Do you not think you have a duty of care to your company’s clients?
If something goes tragically wrong you will also be carrying the can. The balls in your court, what do you want to do?
Already started a disaplinary I'm just after the finishing touches,I can't find anymore bs7671 regs to throw in the mix..also totally agree with youI had a foreman similar to that years ago . He'd go out to a breakdown on a control circuit say....... put a 2BA screw in place of the control circuit transformer fuse , sun to the fault , transformer melts ...back to office ,order a new one then make sure I was sent with it and I'd end up having to trace the fault , while he said stuff like " Dunno why he's so long , its only replace the transformer ...I've been and sorted it once "
Absolutely gutted mate,I wanted to teach him a lesson about work ethic but now it looks like I'm wrong.
No case to answer & he's back to workSo he doesn’t even get pulled up for it ...
