Hey guys, I have a weird fault here with a kitchen circuit and could use some help with it.
Okay so I had a call out with someone saying there power was off in kitchen and first place I checked was the board(3 phase) and the obvious was a broke. RCBO and a loose burning neutral.
Before I changed the trip I checked round to see what was off and upon checking a socket with plug tester (socket switch & trip was off) plug tester came on and upon switching socket on it popped and tripped another RCBO off, switched back on and then carried on checking with that socket noted and came to the cooker, switched the electric hob on and the lights & socket (which were both switched off) had come on with the cooker hob. Even when the lights were switched on once u turned the hob on the lights would flicker like there double fed.
There was also a PIR sensor for the lights which had blown and cables in the fitting itself had melted( switching 28 50w GU10's & was 2KW rated) so anyone got any ideas? Lol I don't apart from neutral to earth fault which I'll be checking for in morning.
