You would use singles anyway in dado trunking, if only for cost, T/E would be unnecessary.Dado trunking is often used in office type applications but didnt I read somewhere to prevent something cant remember what should be singles instead of t and e
You are correct I probably did "over engineer" its part of the way I work!. :xGreen Hornet you don't think you may have been over engineering your design do you.? Schools don't usually draw a great deal of current on the sockets. I don't understand the reference to " a big industrial floor poloisher" ! Old fashioned ballast fluoros have been used for years in offices, still is, along with Cat 2 louvres . Don't see any problem with computers. I would have no problem with dado trunking either TBH. The lighting in 1.5mm is , surely, ok , presumably divided into , say, 4 circuits.If you quoted for emgy. ltg and fire alarm and they have not then they are going to beat your quote every time !!
Unfortunately the building regs and the fire brigade rely on the electrician to be doing the work to the current regulations, I am unaware of what reason the electrician was forced back to do the work correctly but there are some regulations that have to be complied with that have nothing to do with wiring.You have to over engineer schools cos as soon as they get in there its, we want projectors, interactive whiteboards blah blah blahWudnt it be a requirement of Building control or the Fire brigade for LSF to be used throughout?
