- Mar 15, 2009
- 444
- 0
Ok everyone, you may remember the topic I asked on the subject of the meter & head in a cupboard just in the boundary, well here it is first 2 pictures are of a local job by another sparks with an air raid style housing in the front garden for 3 new builds in the rear of a property.
The other pictures are of the housing I have built, brickwork with roof etc for the DNO to run their cable then from their meter to my Fused isolator, and SWA to the property, all the way through the client asked why I ran 25mm 3 core armoured they thought it was a bit large so I told them that it was the minimum size for tails and that you cannot rely on the armour for a CPC so 3 cores plus armouring and insulation make it thick, when EDF arrived to put in the supply they put in a single centre cored 25mm aluminium conductor with a copper sheathing around it ( forget what it's called now ), I had to explain to the client it was only allowed for the DNO's and used by skilled persons ? once it's on your property any stupid person could dig it up and cut through it!! so that's why it's so thick. I also told her the IPX4 light was no good for the sink next to a shower as it had a flexible hose and could be pointed at it, again more arguments, showed her the onsite Guide which say's IPX5 with water jet's so she said it is only a guide and did not matter, God give me strength! got me cheque and got out.
Mike.
Anyway all done now.
Mike.
