The cooker switch does indeed have a socket outlet but I propose to swap this for a single cooker switch which will be installed in an adjacent cabinet.The existing one is directly above the cooker.I have not measured Ra as yet.
The Wylex board feeds the 2x lighting circuits, and 2x ring circuits only.
The cooker must have been an afterthought as this has its sole supply from the switched fuse which is adjacent to the Wylex board.
Technically I could install a 30mA RCD after the switched fuse and leave the tails alone, even if they are in a poor condition but would I have to upgrade the earthing/bonding even if Ra was<200 ohms? I believe so.
Andy has said he would just do the job if it was safe. The existing cooker has been in for 30 years without any problems so what do we do? They are 84 year old pensioners who could do without the cost of upgrading for the sake of changing an appliance.
I am aware of work in kitchens is notifiable.
Dave2
If you say you could not visibly see a rod AND you are considering installing a rod....
How come you haven't bothered to try and check the Ra yet!!!!! bad day explode
How can you start making decisions without verifying the condition of the existing earth arrangements????
132.16... ? no?
"The existing cooker has been in for 30 years without any problems so what do we do? They are 84 year old pensioners who could do without the cost of upgrading for the sake of changing an appliance."
Well tell them to keep the old appliance then.....Ask them if they can buy a new car today without.. ABS breaks, Seat belts, Airbags, Fog lights etc....
They could have 30 years ago.....
BUT they can't today......
even though 30 year old cars can still drive on the road..
in the event of an accident they have greater chance of being killed than in a modern car...
Same for the electrics..
rules & regs have changed....
either do it proper or leave the old one in....
But as SlipSlap said...
in the event of a fault there is more chance they will be scooped up off the floor and put in a box if they keep the old wiring arrangement!
:C
