StephenRussell
I have just fitted a new external light which keeps tripping the circuit breaker.
It is a completely new installation - I have ran a cable straight from the fuse box to the light and a switch live circuit to an internal switch. I have checked (and even replaced) the wiring. To check everything I have removed the light fitting and wired it to a plug and this worked fine (no trip). I also took a short length of cable striaght from the fuse box to the light fitting (no switch) and this also tripped the breaker.
I can't understand why this is happening - as I mentioned it works fine when wired to a plug but not when it is connected directly to the fuse box.
Any advice is greatly appreciated.
