New probes required....
the doctor
Part P Doctor ™
Mar 1, 2008
580
At the college where I work, they have Megger 1500 multifunction testers. I also have one myself for my personal use:p
Mine like the college ones have none of those daft little nipples you slip over the probe tips to make them GS38 compliant. :coat
My question is this........Where do you get spring loaded probes with the little sleeve that covers everything up and will plug straight into the Megger?
Thanks in anticipation....
Alan
Cheers fellas,
That is helpful, I have posted the links to the tech at college. Our wholesaler says there is no such thing as "spring loaded tips":O
Cheers fellas,That is helpful, I have posted the links to the tech at college. Our wholesaler says there is no such thing as "spring loaded tips":O
Sounds like you shop at CEF!
Common wholesaler response, 'I've never seen one, therefore such a thing never existed and never will'.
It's not the tips that are spring loaded... it's the sleeve!When I used to fix electronics we used to use them all the time,, they are great for hooking onto resistors etc....
you know what i mean noz..... :|
