Any neutral on an energised circuit supplying a load will be 'live' once disconnected
just saying
yep. always check neutrals are dead after disconnecting them. probably dont teach you that on many courses
just saying
Hi Murdock
Yes the walls are plastered just not painted or wallpapered and no carpets and yes I've researched about borrowed neutrals and I read about once you pull a borrowed neutral it then becomes live thanks for the advice, I'm just wondering because there has not been any heating on for a few weeks and this damp weather could moister be an issue.
Thanks.
Mel
????????How would I test the RCD without any loads
???????? What !!!still a bit green only passed my exams a few
months back poni said:How would I test the RCD without any loads
I've never had to test one before I've an idea what to do but rather it be clarified first.
RCDs should be tested without any load as the load may interfere with the test current from the meter.Yes I have got the on site guide and a copy of the bs7671 18th edition and it does not say how to test an RCD without a load, only where and when to use them, the only way I have been taught to test RCDs is to do the ramp test as per the schedule of results which on my meter does 6 tests 1x the load, 5x the load and half x the load and record the results which at 5x the load should be less than 40ms and then you test the manual RCD button, now my RCD is tripping on the last test of the half x the load which it shouldn't hence why I asked the question and in answer to your question how would I test a RCD without a load I would switch all loads off remove the neutrals and stick my probes on the load side of the RCD and do a ramp test, I'm not sure if that's correct but that's why I'm asking. As for my exams I've done I can only tell you what I've been taught I can't help that, I got all my pass certification and been told I can go out and do electrics, my stupid questions are down to inexperience and lack of knowledge hence why I am asking you guys cause obviously they don't teach these things.
I believe it has had new wiring my friend only just purchased the house at auction and looks new just missing the db hence why she asked me, now got this challenge but I see it as a learning curve.
