safedepth
Evening all,
Went to look at a job today and found the following.
Existing service head in meter cupboard adjacent to properties gate, immediately next to it is a second meter cabinet housing a switched fuse and single henly block.
Property is approximately 5 meters from meter boxes. 25mm tails out of head cab and into second cab and switched fuse. 16mm swa glanded at second cab, phase and neutral off to property, earth terminated into the henly. No earth rod at cab's. CU in property is rodded at point of entry.
Please correct me if necessary but I'm thinking the swa needs an earth at the service head end and a 100mA RCD, all to protect the swa.
I haven't been in the property, I was called in to look at putting a new supply into a different building no more than 15 meters from the supply cabinet.
I was going to run a new swa submain from the second box, via a 100mA RCD and switched fuse into the new building, rod again and fit a small CU with 30mA RCD's.
Sorry it's long winded and a beer for all those who have stayed with me.
