hi, just a couple of questions as i'm learning. (3rd yr a college) and a bit confused
If you you were to perform a ZE and find, you had no earth connection at all for example on a tns system. to make the installation safe you install a rod and make the installation a temporary TT system would you then have to install an rcd if for example if was old fuse board with rewireable fuses.
secondly, when performing a consumer change you find the lighting is tripping the rcd, you find its a insulation problem to earth:
1. the lighting circuit put on an mcb and noted at the distrubution board
2. rectify the faulty circuit at your own cost as should have been identified and rectified prior to fitting consumer unit
these are two different answers from two sparks the first answer i thought all circuits were to go on rcd now.
cheers
cheers
