Not very often one has an opportunity to disagree with the "Special One".
I would hope that everyone always has opportunity to disagree with everyone on the forumbulator...
As you say if just doing a CU change and customer not requested any other alterations circuits often old circuits can be reinstated and still be within regs..
But there can be different considerations if asked to fit some new or additional light fittings to a circuit....
As well as the IR I would also be considering if there is enough cable to work with when terminating the accessories..
often they can be cut very short on old installations from years of trimming back when new switch or lamp fitted...
Or the cables around the lamp fittings can be very brittle from the heat...
again doing an IR at a cu may test all OK..
but when you disturb a ceiling lamp fitting..
you may get some deteriorating or damaged insulation could affect those results...
Also have to consider if there is ONLY one lighting circuit for the whole property,
which often there was on older wiring.
Its a bit like keeping an old car running...
At some point they can just become too uneconomical to keep fixing to keep em roadworthy...
Some old wiring can be like that..
fix and bodge here there and everywhere to keep a circuit running when if it had been replaced 10 years ago it would have been more economical in the long run.
Guinness
