Right..heres my fourpenny worth on this one.
I will just add at this point here I have just completed some electrics on a building extension for a builder..
(Thats were me dodgy socket in the black museum was taken at)
Anyway there are a few bits of paper that have to be transfered between various persons..
and there are various ways it can be done all quite legitimate and above board..
Some ways are just easier and less hassle all round for everyone. so consider the options with the various persons....
Mr 'A' the LABC building inspector:
he has to tick some boxes to verify all is hunky dory with the building works,
If you make more work for them to do..
They can get a bit more picky and arsy with the builder and associated tradespersons insisting more works is done to a higher standard or similar.
If they know someone else is going to carry the can for the electrics..
all he needs is to see or have a copy of a certificate with a registered sparks name & reg number on it. Then he can tick that box and get on with more pleasurable things for his own benefit.. (happy LABC inspector!)
Mr 'B' the Builder:
Bottom line is he has got to construct something and get it all finally passed by the LA building Inspector so he can get his final money off the customer.
If the builder has a good reputation with the LABC, and can give copies of all relevant electric, heating, gas, structural support certificates etc..
Builders life runs smoother and easier with inspection visits.
So if builder has a copy of fully signed EIC he can give to Building inspector on the final inspection all is easy and simples.. everyone happy!
Mr 'C' the electrician:
If you can keep life a simple and easy for the builder as possible you will get more work from that builder.
So if you provide all the necessary certs for him to give to LABC inspector he's happy.
Also when your annual inspection comes around they will be expecting to see evidence of some notified work from jobs done over the past months. So you notifying the works provided extra back up of your work.
So personally I just do the work
notify it as normal, Via Nic
Give customer original certs, all the work and the bits are what they are paying for anyway!
Give builder a photo copy of those certificates..
that he can then give to the Building inspector when he comes to finally look at the job.
everyones happy..
No probelms...
