Second fixing a kitchen today that I 1st fixed four weeks ago . We had determined with the customer that the oven was to need a 30A supply and the hob was gas .
Customer alters it without telling me, so I fit a 45A DP switch ,connect the 6mm , pull the oven out ready to connect the 6mm tail, theres a 1.5 flex hanging out the back.!! Oh well I think , derate the breaker , waste of expensive 6mm.
Go to connect the cooker extract , glance at the gas hob, Oh look! Its become a 30A Induction hob !!! And all I've left is a spur off the ring to feed the ignition . Wonderful.
So , have to divert the 6mm underneath and up to the hob, which has a 4 X 2.5 flex on it . The cores are crimped together into pairs, I go to connect the pair with the Brown to L and think, best just read the bumph first .
Brown crimped with Blue is Neutral ........ Black crimped with Grey is Live . It can be used on 230v X 2ph with 2 neuts ...... 230v X 3ph with 1 neut or 230v SP....... BUT NOT 415v X 3PH .
Must admit that brown threw me for a minute ,and the L being Bk/Gy HHhmmm . A Smeg thing BTW .
So moral for today is :-
(a) Never assume the customer has any sense.
(B) Always read the bumph first .
