Hello Sir,Is this a series or parallel circuit???Series
10+9+8+7+6=40ohms
I=V/R
I=50/40
I=1.25A
P=I*V
P=1.25*50
P=62.5watts
Parallel
1/R=1/R1+1/R2+1/R3+1/R4+1/R5
1/R=1/6+1/7+1/8+1/9+1/10
1/R=0.645
R=1.54
I=V/R
I=32.46A
P=I*V
P=32.46*50
P=1623watts
Sounds like you have a mix of series and parallel. Have you got a circuit diagram?Hello Sir,My head is really in trouble about this,,, the way how you explain your calculation is pretty understandlbe and looks easy to work out , but this practice materials i'm using is bit different...
the answer for that question is
156.5.watts ....
and this is what it says
"remember work the parallel circuit out first then add it to the series connected resistor. Then use ohms LAW to find P, once I total is known"
yea it the diagram it saysSounds like you have a mix of series and parallel. Have you got a circuit diagram?
OK, now we have all the info, the early shift can have a go:yea it the diagram it saysR1 and R2 in parallel
R3 connected from r1/r2 in series
R4 and R5 connected from r3 in parallel
thank you , i got it ... thanks to all who shared thier ideasOK, now we have all the info, the early shift can have a go:R1 + R2 in parallel = 1/((1/6)+(1/7)) = 3.231ohm
R4 + R5 in parallel = 1/((1/9)+(1/10) = 4.737ohm
Total R therefore = 3.231ohm + 8ohm + 4.737ohm = 15.968ohm
I = V/R = 50V/15.968ohm = 3.131A
P = V x I = 50V x 3.131A = 156.55W
often useful to give all the info in the first post...yea it the diagram it saysR1 and R2 in parallel
