old wired door chime
r.b
Feb 8, 2011
379
a door chime has stopped sounding its a wired one I presume its old bell wire.If i were to put a wired kit in how many cores does a bell wire need for it to work normally?between chime and push sure its 2 the last one i did had a transformer?
Check the transformer.
Check the pushbutton.
Check the bell.
Replace whatever is faulty.
Simple.
Why do you need to rip it all out and start again?
2 cores unless you want an anti-tamper loop too (just kidding)
Same way as a loop in lighting circuit I tend to use 2 core 0.5 mm flex especially if its longish runs or use alarm cable and double, treble the cores up
