Well, if a maze was labelled it wouldn't be a maze would it now? It would just be a route map!as above,
and if nothing wired then just turn on the boiler, manually open a valve and see what gets hot,
on saying that though, it does my head in too if they are at the boiler and the pipes disappear into a maze, and not labelled, headbang
The plumbers don't label what is the zone valve heating and what is the zone valve hot water what is one way of knowing which is which?
There IS no "normal" they can be placed in any order the plumber feels is best or easiest.Sharpend whats the lower valve normally heating or hot water you just said valve?
Ah yes, the good old " neighbour comparison"get a competent person to have alook...
or go and have a look at the neighbors house....
they may have nicer biscuits and an attractive daughter who can make a good cup of tea ..
:coat
:slapOn these boilers they are temporary flexed in by plumbers and I come in and wire basically if I did get the hot water and heating wires mixed up I would know about it on the s plans?
fixed that for you:slap
If you can't figure things like this out how did you get a job TRYING TO WORK as a sparks?
:shakehead
Well from a purely existentialist point of view...the cable on the left is more than likely to NOT BE the cable which is on the right....HOWEVER. If viewed from a reverse perspective then it may indeed be on the left and not the right BUT only if it wants to be viewed from this orientation and there is no Parallax error.I`m sorry - could we have this moved to the jokes area?
r.b. you simply can not be serious - this is, pure & simple, a winding up exercise........
Suppose I said to you that I`ve got two wires coming from my consumer unit, they`re both the same size, and one is the upstairs lights, the other is the downstairs lights. Which one will be on the left?
As jokes go - it wasn`t bad............. :coat
