I know for a fact that our sky+ HD box won't record without a valid subscription
oh,I know for a fact that our sky+ HD box won't record without a valid subscription
The skybox f5 is nothing whatsoever to do with sky. It is not what's normally known as a "sky box"you could get a skybox f5, [example]
that allows you to record, amongst other things![]()
are you sure about that?
my mate has a sky+ box and Im fairly sure he can record on it, freesat only of course,
but, I would need to ask him to be certain.
I know it's not what is generally known as a sky box, but it can do so much more than a normal skybox (without sub) or freesat box can.The skybox f5 is nothing whatsoever to do with sky. It is not what's normally known as a "sky box"
A Sky+ or sky HD box can record without a subscription, but it's not easy.
With the previous blue sky viewing cards, if you removed the card before the subscription ended (while recording was still active) and then left the card out of the box for at least 3 months (by which time they had stopped sending the command to disable the recording function) then it would still work to record the free channels.
I have been (and still am) using a Sky HD box like that just to record and play all the free channels :innocent
However with the current white viewing cards, that loophole is closed and it will not work.
BUT if you have had a sky subscription for a long time, and previously had a blue viewing card, and are a bit of a hoarder so you still have it somewhere, then plug it into your box and try it. You might be pleasantly surprised.
There is also at least one version of sky+ box where someone has re written part of the software to allow recording without a card. It requires reprogramming one of the flash chips. You sometimes see modified boxes for sale on ebay, but frankly the asking prices are so high you might as well buy a freesat box instead.
:slapCanoeboy said:XBMC is very good, I have a mini mac instead of a dvd recorder and its great - It has XBMC installed on it and that works a treat
No it's off the Astra 1 satellite at 19 degrees east.Dave is RTL off the Astra Satellite the same one for Sky ?
But NOT on iAnything without jail breaking it!Canoeboy said:XBMC runs on OSx
how have you managed to get 3 lnbs onto one dish for 3 different satelittes,No it's off the Astra 1 satellite at 19 degrees east.
you will need a second dish, or as I have one dish with 3 LNB's (astra 1, astra 2 and hotbird)
