A publican that I've done some work for in the past asked me to have at an aircon unit that wasn't working correctly. I said that I don't normally do them but I could have a look and if there was something I could do I would but that I might not be able to do anything.
So I get there and its in the cellar... It's a big old 3 phase unit fed from a switch fuse (3036). When you turn it on it operates for 20 seconds or so and then turns off....after another minuite it turns back on and the sequence repeats (ish)
So I checked out the contactor and thermostat and they were both ok... the power was being knocked off by the compressor unit so I go and have a look...
A quick check of the compressor and I can't see anything... I had just turned around to get something out of my tool bag... I was thinking of shorting out the klixon (but hadn't yet) and there was a bit of a bang and a massive spray cloud...... Yes the PRV had activated... FFS I'd just had my head in there...
One thing I know know is that it wasn't short on pressure
I've left it with him.... It'll need a new system IMHO
