Lostmejunk
- Joined
- Dec 31, 2019
- Messages
- 5
- Reaction score
- 0
Hi, excuse the ignorance here but I am currently replacing an existing switch with a 2 gang to wire up a new outside light. The current switch has a live, neutral and earth feed (which appears to be only from the ceiling rose). The new outside light has the same. How/can I wire this correctly? I presume I should bridge between the COM port but how do I wire the new light to work correctly? Standard gang with com, L1 and L2 for each switch. Old switch works fine as you would expect an I missing an additional feed?
Source URL: https://www.electriciansforums.net/threads/outside-light-wiring.181934/#post-1598202
