tom1
Distinguished Member
- Aug 7, 2009
- 2,330
- 0
got a 2.3 kw oven to install,
there is 1 socket on on this side of the kitchen there is also a fridge frezzer near the oven, they are tight on the money, so much so that they did not have a 20 amp double oven as they would definatly had to have a new feed to it.
the socket looks to be a spur off the ring.
2.3 kw and separate ring for kitchen so i dont have a problem with putting it on the ring but instructions say connect to dp control unit 3mm clearances on all poles, would a dp socket satisfy this so both oven and fridge can be plugged in to the one socket.
or swap the socket for a dule pattress with a fcu and single socket but would this be a spur off spur, cant see difference between 2 singles or 1 double except all are rated at 13 amps?
thanks
thanks
