Dunno ....a broken PME neutral and a pisser up the pisser .whats the worst that could happen?
the lights will have their own CPC (unless they are class 2), bit like saying you must earth the metal bench because there is a toaster on itThat doesn't sound unreasonable to me, as the ceiling presumably supports light fittings. Only thing is the joints of the grid are hardly of electrical bonding standard.
That just about takes the biscuit .............unless YOU know a worse case of bonding nonsense.And also having to chase the floor on stairwell landings to run a 6mm earth to the handrail.
Oh Dear God !!! Talk about someone with nothing better to do . It gets worse !!!Glasgow council required a bit of 4/6mm and two yellow ring crimps across every joint in galv capping. Clerk of works would walk around after the job , ohmmeter in hand shoving probes through the finished plaster checking for continuity
Just thought of another OTT wallah on a Health Service job .... ( Remember that it was all B/E conduit then) ... insisted that all the switch drops were painted with red oxide paint . This meant cutting & bending the tube , making sure it fitted , then unscrewing them , put them aside, paint them on all sides and wait for it to dry .
If these guys were in contracting they'd either have to forget all that carp or get kicked into touch .
It was flavour of the month for a while Geoff but was soon abandoned . I've seen miles of 6mm earth jumping across every tee bar for miles ...... in my opinion another load of nonsense ....no one does it now .That doesn't sound unreasonable to me, as the ceiling presumably supports light fittings. Only thing is the joints of the grid are hardly of electrical bonding standard.
