First of all..can you use a passive infra red to control a florrie or will it require a new fitting
you have a number of florrys upto 500W on that particular pirisn't there a minimum wattage too? Some small flourescents don't use much power...
Don't think minimum is too much of an issue..isn't there a minimum wattage too? Some small flourescents don't use much power...
thanks for the replies guysFirst of all..Ruddy good Avatar there M8 Applaud SmileyApplaud SmileyApplaud Smiley
It just so happens I have a PIR here ready to fit on job later this week...
the bit of paper inside says
load:
2000w Tungsten Halogen (4 x 500w)
1000w Incandescent (10 x 100w)
500w fluorescent.
So I say
YES!
thats an 'IQ' E-700 PIR by the way!
Only real way to get florries to output less is to dim them. However it requires specialised control gear to replace the choke.... You can't just hook them up to a dimmer switch.I've spent many hours looking into this as our 700+ dimmable florries in the venue used phase dimming which is no longer made (and the few that are left in the country are at an asking price of
Tis a pleasure Craig!thanks for the replies guysi will check the pir
you all deserve a Guiness Drink
They are breaking all the time, we are loosing 5 to 10 fixtures each year we re-lamp. We don't say 'Oh poo', we say 'sod it'. :_|So I guess you would say Oh poo! if you broke one of them! :^O :^O:^O
:O:_| :_|They are breaking all the time, we are loosing 5 to 10 fixtures each year we re-lamp. We don't say 'Oh poo', we say 'sod it'. :_|
steps - couldn't you remove a few tubes if twin tube fittings?while we are on the subject of florries,how do i get a florrie to put out less light?!
600mm reflected diffuser twin tube recessed fitting, about 10 of them in an office and the staff are complaining that too much light, any ideas on what to do?
can I get any benefit from fitting a different spectrum of tube?
am not sure whats in at mo but going in morning to have a look before office opens.
Have you tried using the encapsulated tubes - various shades/tints are available. I realise that the power consumption will not be reduced but it may provide an easy fix.while we are on the subject of florries,how do i get a florrie to put out less light?!
