been doing some testing at a industrial unit earlier, and a number of failures
the worst:
toaster - very old. removed cover of plug to find no screws in the terminals. slight burning marks on L&N conductors (no surprise)
Drill & extension: damaged flex. repaired with bitumen type tape. so stiff, this also damaged the flex with movement
4 way adapter: completely smashed, and fully covered in duct tape. tape carefully cut away at one of the sockets so it could be used
few other things which were repaired and then passed (cable sheath not clamped, broken plugs etc)
bloke said he was expecting the above items to fail, yet they were still in use until i failed them
so whats the worst failures youve came accross?
the worst:
