- Nov 28, 2009
- 14,670
- 827
I have to do the PAT testing at the village hall. What is the re test interval these days?
on the rare occassions I do any PATing I charge my usual hourly rate. 20p an item is just not worth bothering withOf course, good luck to the IET getting the 20p-per-item types to shift from "10 seconds to plug in, push button, apply sticker - next" to more of an inspection and thought process, I bet most don't even check inside removable plugs, it's literally not possible to properly assess an item to the modern standards if you're one of the oldschool "2000 items a day" crowd. I'm fortunate enough to not be trying to earn a living directly from this, it's just one part of my job and for our own equipment so they'd rather I do my job properly. We used to use the "pay someone peanuts to come in and do it all" approach and I've seen my share of items with their green pass sticker on the plug top and the cardboard instruction sleeve still on the other side.
I think you have been taken in by some misinformation it has always been ISITEE it just got interpreted as PAT in the early daysAlso I forgot to add before anyone pulled me on it for not being portable, nowadays "projector bolted to ceiling" does need at least an inspection as it's no longer "portable appliance testing" but now "in-service inspection and testing of electrical equipment" and the contents of the CoP reflect that... but I suspect that everyone who's received training as recently as me has probably been taught to yes be diligent but also that they're allowed to be realistic e.g. say "let's not worry about that item quite as often, because it's not going anywhere and no one is even likely to touch it". That's the mindset I was taught anyway. You're encouraged to use your noggin more rather than "push button, come back next year", and I think they'd rather have that aspect of realism about whether something is reasonable, so that equipment is at least looked at every so often even if it's e.g. every five years rather than a mindset of "it's crazy to look at that once a year so I'm just never going to look at it".
Any signs of deterioration of the appliance should give a good indication of what type of environment it is being operated or abused in, why does it matter what the regular environment is if the appliance is portable it is easily moved and could be used in any environment.What we did get taught is to think about whether "please just pile all your portable equipment into the middle of this room for testing" is really suitable, because when it's been piled into the middle of a room you don't really know its regular environment. So my thinking was kind of extrapolating from that.
The person carrying out the test and inspection can recommend any T & I frequency they deem suitable but ultimately it is down the the duty holder or person passing the order for testing and inspection that takes responsibility for maintaining the recommended testing cycleWhen it comes to doing a risk assessment (from which you can decide on frequency) it's stated as the responsibility of the dutyholder (facility manager, building manager, landlord, etc) so yeah someone who's just doing inspection and testing isn't directly responsible for that unless they happen to also be the dutyholder. But then also "A dutyholder may enlist the services of a competent person to assist in this process" which is where the job ends up passed down (if only as "advice") which honestly makes sense to me, I'm trained in what I'm looking for and what's more likely to make it fail (e.g. vibration loosening earth bonds) so of course I'm probably better placed to offer advice on whether something should be checked more often or if it can wait a bit longer. It just happens to be the dutyholder who bears the ultimate responsibility and I imagine if something went horribly wrong, they'd be asked "well did you listen to the advice of the competent person when they suggested you look at it every year? Why did you leave it for 5?" or whatever.
I doubt we will ever be totally rid of the flyby test and inspection guys as most dutyholders have little or no knowledge of what they are buying so the cheapest quotation will generally always win the dayOf course, good luck to the IET getting the 20p-per-item types to shift from "10 seconds to plug in, push button, apply sticker - next" to more of an inspection and thought process, I bet most don't even check inside removable plugs, it's literally not possible to properly assess an item to the modern standards if you're one of the oldschool "2000 items a day" crowd. I'm fortunate enough to not be trying to earn a living directly from this, it's just one part of my job and for our own equipment so they'd rather I do my job properly. We used to use the "pay someone peanuts to come in and do it all" approach and I've seen my share of items with their green pass sticker on the plug top and the cardboard instruction sleeve still on the other side.
