Hi peeps,
Never "sized" a power supply for a pc before.
Anyone fancy helping me short cut the research process please?
I need an ATX sized power supply to run:
Asus PC4800 mother board 20/24 pin ATX connector & 4 pin power connector
Processor is Pentium 4, can't remember the speed etc. and can't check it as the machine won't power up, the PS has failed!
PCI graphics card with 6 pin connector ATI Rage series
2 off S-ATA 5.25" HDD
2 off IDE 5.25" HDD
2 off 5.25" DVD RW drives
1 off 3.5" FDD
(Want to fit an additional 1 off 5.25" FDD if I can get hold of one!)
5 off case fans @ approx 15W (by ohms law & fan W rating, some are A rated some are W rated)
I make the HDD at around 40W.
Anyone have any ideas what the graphics card, MB & processor will take.
MB has 4GB of 184 pin DDR DIMM on board.
It was running on a 570W Trust OK, but HOT, all PSU fans on all the time.
Thing is once you get bigger then you get pricey!
I actually will have the following peripheral connectors inside:
2 off FDD
4 off 4 pin HDD
1 off 6 pin graphics
1 off 20/24 pin ATX MB
1 off 4 pin MB
5 off 4 pin Fans (same connector as HDD)
Thanks peeps
2 off IDE 5.25" HDD
1 off 3.5" FDD
2 off FDD
4 off 4 pin HDD
1 off 4 pin MB
Thanks peeps
