- Mar 28, 2008
- 14,487
- 1,155
Crabtree CFL Pendants....
Any one else had any problems with them NOT switching 'ON' after being turned off following a long(ish) duration of being 'ON'?
These jobbies:-
As per 'need a few Low energy "Fittings" to keep the building inspector happy!!! :|
Got a job with 10 fitted.... 3 have been playing up! being Naughty pendants!!! X( :_|
Done all the swap bulbs around business to check if bulb or fitting...
and I know the Crabtree catalogue says...
Ideas anyone?
Or any had similar problems?
Can I change my name to :- "NOITACOL LAICEPS"...
Just to keep Patch happy?! ]
I know he loves name changes!!!! :^O ; \ :x
These jobbies:-
But we still have three pendants that are NOT playing proper!!! X(CFL COMPACT FLUORESCENT LAMPHOLDERThe design of the Lampholder accepts an industry standard 4 pin 10,13 and 18W G24q1 and q2 lamp. This reduces the power
consumption, when compared to an equivalent incandescent lamp, by up to 80%.
The Lampholder is designed to European standards and has a diameter of 42mm, which is larger than the typical Lampholder which is 29mm.
A Safety feature which protects the installation will disconnect the supply to the Lampholder:-
During a lamp change, when no lamp is present, or in the case of lamp failure at the end of lamp life.
This Safety feature is reset by switching the supply to the fitting off for 10 to 15 seconds.
{extract PAGE 202}
Ideas anyone?
