Piece of string
Evans Electric
TEF LINUX ADMIN™
Sep 15, 2008
23,507
527
Birmingham
Hi, Patch, earlier today the missus dropped the piece of string that was tied around the joint of meat, it had some meat stuck on it , Oscar the Idiot Westie snatched it up and swallowed it . It was about 9" long , do you think it will pass through or what ?
Deke
My dogs have eaten worse, the dog may become distressed if the string comes out as a long length, the anal muscles will contract, the best way to deal with this is to make the dog calm and gently pull the string with an even pull, do not force it, the calmer the dog the better the procedure, if the dog gets very irratated then always consult a vet.
The string will come out on its own in most cases. There can be problems if it does not come out, it will not digest and can in extreme cases cause blockages, its rare but possible.
Anyway Patch will give you the proper info when he sees this post.
mmm - hopefully this will be ok but keep a close eye on little Oscar.
Long thin things like string can cause the intestine to bunch up and cause what we call a 'linear foreign body'.
Most of the time it will be fine, but if he stops eating or looks miserable get him to your vet, pronto!
:D
Thats not the same string you use instead of a laser level is it Deke?
:eek: :O:O
Do you have more than one piece of string... you rich string snob!
]:) :p
:innocent :innocent:innocent
Four days now , Oscar is now called " Stringfellow" . Eating normally, carping normally, acting normally. I have the dubious duty of inspecting said carps each morning, lovely !!
Any further thoughts , Patch ?
Looks like everything is fine, as Patch says it should have passed by now and if he is eating normal and is no way lethargic then it looks like your in the clear.
If it had started to come out in one long length, it would have made a useful alternative to his usual lead.
:innocent
