Hi there,
Just after a bit of friendly advice regarding an emergency lighting issue I've come across this week. I've been doing some work this week on some apartments in an apartments block. In the communal hallway area there are several lighting points with remote PIR sensors. These lighting points also double up as non-maintained emergency lighting points. It appears that a little while ago the lights stopped working via the PIRs. New bulbs haven't made any difference. When I removed the permanent live from a few of the lighting points to replicate a power failure the bulb lit for a couple of seconds, then went off again. I haven't come across this before ( I don't do a lot of wok on emergency lighting points) and was hoping someone may be able to suggest what might be the issue(s) here?
Thanks in advance for your help
