why has it done that, prob because double clicked, i will have a look.Depends if you want it to come on when the light is off!Go delete your duplicate post Tom.
you need to bypass PIR and wire it into the sw live then. No?why has it done that, prob because double clicked, i will have a look.dont mind that it only works when the lights switched on, but would not be happy if it came on with the lights and then went off after a few mins
yer will have to have a play, hopefully it will just switch on the sensor.With most PIRs when the power is switched on they come on for their defined period! Wire it up to a 3 pin plug and have a play.'s what I'd do.
why? same circuit?yer will have to have a play, hopefully it will just switch on the sensor. would it be bad to take a perm live from the switch and a neutral from the light ?
bathroom light and bathroom switch.why? same circuit?
