southsparks
Two months ago I was asked to fit some (supplied) LED light fittings to a building frontage, three are PIR type, and two without. Just recently
the three PIR type have started flashing on & off every time they are triggered. The other two are working OK. It just happens this
circuit is photo-cell operated, so the PIR fittings are turned on & off every day. I realise that PIR fittings should be fed from a permanent
supply, but I thought it would be OK to use the PIR ones on that circuit. I have done all the usual checks to fittings supply, and tried by-passing
PIRs, to no avail. It looks like the drivers are now at fault. I have taken them down & hope to be asked to fit non-PIR type, to simplify the
set-up, to all on dusk to dawn. I think otherwise, I would have to run a separate circuit for any new PIR type fittings, and leave the others
on the photo-cell. Would this regular switching off & on every day be the cause of the fittings drivers to fail? The instruction say the lamps can
be turned on & off up to 15,000 times. They are LAP make & 50watt. I wasn't too keen on mixing the two types of fitting on the same circuit
but thought it wouldn't matter if the three PIR fittings went through their switch-on test mode each day. Looks like I was right to be concerned
about the possibility of a problem developing. I can mention that I tested all the fittings back in my work-shop and they still all strobe.
Has anyone else come across this problem? thanks for any help or advice you may have.
Southsparks.
Southsparks.
