Traineesparks
- Dec 5, 2011
- 13
- 0
Good Afternoon,
Finger crossed someone can shed a little light on my problem as i am completely miffed and out of ideas
Basically i have a single 1 way light fitting in my bathroom operated with a simple pull cord, i have replaced the pull cord with a Occupancy Sensor 360 degree PIR Light Switch, nothing complicated single line in single switch line out (neutral) and single earth at the switch.
However......with a standard 60w ES lamp (bulb) in place nothing happens, i can hear the PIR switching as i am present but the lamp (bulb) doesn't illuminate when i replace the standard 60w ES lamp (bulb) with an Energy saving lamp (bulb) it continuously flickers !!
I have tried different lamps (bulbs) and they work in different outlets so i know they are fine, i have also tried the PIR on my lounge circuit which is identical, single line in single switch line out and single earth at the switch using again the same bulbs and the identical same thing happens.
Please don't let this beat me, any help with be appreciated.
thanks in advance.
thanks in advance.
