gselectrical
- Oct 13, 2009
- 627
- 0
Afternoon all.
I carried out a PIR last week on an ancient property. Looks to have been rewired about 35 years ago. Anyway, Whilst carrying out end to end tests on the rings I found that the readings on the CPC's where very low. Eventually found a large adaptable box where most circuits had been extended, I'm guessing the CU was relocated at some point.
All the CPCs within the adaptable box had been jointed together using a large earth block (hence the very low ring CPC reading)
What code would you give this? It was that much of a mess i couldn't really test if a circuit was sharing another circuits CPC.
Also, what code would you give old switches & sockets mounted on wooden backboxes?
Cheers
GS
Cheers
GS
