Please help, again.
Steviec57
Mar 28, 2012
12
I've been changing a few light fittings in our house in my spare time, and have done a few so far, with the instructions that you guys gave me a couple of weeks ago. I've just come up against another problem now though. The colours of these wires are different and there is a wire less than in the others! (see the attached photo).
It is in the kitchen where I've already done one at the other end of the room with an extra wire and no yellow one!
Please help again, guys.
Cheers
Steve.
I could guess, but then again I could easily be wrong.
You should really be taking note of which wires go where before you dismantle it.
TBH you're going to have to remove (not disconnect) the switch front to see what wire does what.
As I said, I'd done a few that were all the same but just disconnected this one as if it was the same as the others. Hey, if I wasn't daft, you'd have nothing to do on a bank holiday Monday. :)
Post #3 on your previous thread...
http://www.talk.electricianforum.co.uk/do-yourself-diy-electrical-forum-electrics/19763-please-help.html
For anyone reading this thread, the important thing is to look at the wiring BEFORE you remove the old light fitting and draw a diagram of how the old fitting is wired. If in doubt, label the wires in some way so you know which is which.
I can only guess you didn't like the previous advice as you ignored THE MOST IMPORTANT RULE!!!! headbang
Without a meter to test the wires... and/or opening up some other accessories to trace the cables out...
They could be anything...
the yellow & blues may be lives or neutrals...
I guess the red is probably a live....
But thats not always the case!!!
Attachments not working for me to see?
:C
---------- Post Auto-Merged at 19:12 ---------- Previous post was made at 19:10 ----------
re-post switch pictures... :pray
My guess and it's only a guss without the photos they've used the 3 core to the switch red as perm live yellow as switch live return and blue as neutral to switch they they then have took a twin from switch to outside light ive seen it done on a few occasions
Is the red yellow blue all at the light switch
For some reason the other attachments worked for me and I have duplicated them above.
Put your yellow out of 3 core with red from twin and earth in loop connector put your blue from 3core with black from twin and put the last red from 3 core in live
