Please Help
Nov 15, 2012
7
nuneaton
en-suite light and isolated fan, bedroom light don't work changed all bulbs and checked fuse box nothing has tripped the house is 7years old still no joy thanks for your help
en-suite light and isolated fan, bedroom light don't work changed all bulbs and checked fuse box nothing has tripped out still no joy thanks
Is there a fused spur somewhere outside the bathroom I've seen on numerous occasions on new builds they do this the fuse may well of gone. Probably best get a local spark to check it out if the fuse has blown u need to know why not just put a new one in and forget about it
If nothings tripped, no fused spur then it sounds like it could well be a
Loose wire either at bathroom or bedroom light point
Probably a neutral wire, a spark will find it in 20 minutes
I recon the copper thieves have nicked a bit of your cable going from your switch to your light. Buggers they are
thank you everyone I checked the connections and a earth wire came out the ceiling rose in the bedroom causing the fault in en-suite and the other bedroom ..thanks again for all your advise
