plumbers / gas fitter
its the responsibility of the electricain to move the outlet, dont ask me why it just is.!
i do not relish that task as the pipe will need to be pushed out of the way just to get the plate off.
Thats one of the reasons why I insist on doing my first fix AFTER the plumber.
Do not get me wrong there are some good plumbers out there as there are bad electricians, it is just that I have pride in my work and like all my installations to tick and cross all the boxes.
When a plumber has followed me I have found central heating pipes laid on top of cables, cables used as a bending aid to get around a corner, radiators positioned on wrong walls etc etc.
Now I do not run the risk, I wish I had kept a photo I had where the main 22mm gas pipe was run vertical in front of the consumer unit, so close that you could not open the cover to re set any mcb.
(for any one interested the regulation distance is 150mm)
returned to a job today to tind that the gas fitter had been in to install the gas pipe for the cookerstraight over the cooker connection unitX( X(
You would have to be either lazy or stupid to plumb this, or perhaps both :|
Welcome back JL,,,,are you here for a while, or is it a flying visit????
How is/did that job go???
still on it m8. i took a sparky on ands 2 plumbers 3 months ago so things ok for the min !! touch wood ... more wood and even more wood. :)
Thats one of the reasons why I insist on doing my first fix AFTER the plumber.Do not get me wrong there are some good plumbers out there as there are bad electricians, it is just that I have pride in my work and like all my installations to tick and cross all the boxes.
its always nice for the sparkies to notch out for us and have lots of lovely soft cables to lay our pipes on . :) hehe .
