I assume you are on about transistor switching?
To test a PnP transistor
set multimeter to DIODE test with red lead in V / ohms terminal & black lead in common terminal of the meter.
connect meter leads to transistor;
Black to base
Red to emitter & then collector
You should get a reading from both positions, you've prooved forward biased.
Reverse the leads at the transistor;
Red to base
Black to emitter & then collector
You should get O/C prooving no conductivity between pn junctions.
Take a resistance reading between emitter & collector to proove no S/C.
To test a NpN transistor;
Set the meter up in same way.
Red lead to base
Black lead to emitter & then collector
Reverse the lead connections on the transistor & as before you need O/C
Resistance test between emitter & collector should give O/C.
Take a look at this site to explain the PNP & NPN & how they are used for switching or amplifying.....
http://www.electronics-tutorials.ws/transistor/tran_2.html
http://www.electronics-tutorials.ws/transistor/tran_3.html
http://www.electronics-tutorials.ws/transistor/tran_4.html
Far easier than me trying to explain base biasing voltage controlls the collector/emitter.
Gotta go have a few quotes to look at tonight.
