Welshdragon
Hi all,
I am building a portable workstation to hold 4 power tools IE: Router, Saw, Disc sander (Drill powered), Small Drill Press.
The idea I would ideally like is for each unit to only be powered at any on time without the others being able to switch on until the one in use is switched off, & I would like to use & also to prevent accidental power ups.
I am thinking of using
1. 1 x 16A NVR switch with a big emergency stop button.
2. 1 x 4 Channel remote switch.
I guess I would need at least a minimum of 10A remote.
The specs on 1 I have been looking at are
Specification:
Model: CJY-2204
Name: Wireless Relay Switch
1. Working voltage: AC85C-250V
2. Operating frequency: 433MHZ
3. Quiescent current: 8.5mA
4. Load power: 2200W
5. Receiving sensitivity: -105dBM
6. Work: Jog / self-locking / interlock
7. Output signal: four AC220V output voltage signal
8. Coding: learning code
9. Modulation: ASK
10. Working temperature: -10 ° C ~ +70 ° C
11.Channel: 4CH
12. Wiring Method: Fixed wiring terminal
13.Rated load: 10A 250VAC / 10A 125VAC/10A 30VDC / 10A 28VDC
14.Dimension: 6.5cm * 3.5cm * 1.7cm
Would this combo work.....??
How would you best wire it up.
The main reason for the remote switch, is to prevent anyone from using it, that is not authorised or trained to use power tools.....
Kind regards
Thank you for taking the time to look
Any help / advice is gratefully received.....
Specification:
Model: CJY-2204
9. Modulation: ASK
11.Channel: 4CH
Kind regards
