power factor
PoorFish
Oct 22, 2008
158
what is the power factor of a circuit with a 4 ohms resistor and a 10mH inductor??
any ideas anyone
I have tried the R/Z formula but it doesnt seem to work
regards P
Hey I posted the exact same question as you a few days ago with the same title :p here is your awnser credits go to wayne
Find Z first
Z = √R
cheers Bobby
getting late and been at this too long tonight
i must have looked at that post a number of times already
thanks for reply will look at it closer tomorrow
PatGuiness Drink
for this question do you not have to work out the xl inductive reactance? -
(xl = 2 x crbvcurbvubruvbruvb x f x l) xl = 2x3.14x50x(10x10-3=0.01) to work out impedance?
I get
R = 4ohms
Z = 4ohms
so pf = R/Z = 4/4 = 1
is that correct?
for this question do you not have to work out the xl inductive reactance? - 2x3.14x50x(10x10-3=0.01) to work out impedance?
I get Z = 4ohms so pf = R/Z = 4/4 = 1
I would agree you need to work out the imductive reactance XL.
With no frequency given you can only assume 5o Hz so
XL = 2 x 3.14 x 50 x (10 x 10-3)
XL = 3.14 ohms
Impeadance (Z) is the Square Root of (R squared + XL squared)
Z = Root ((4 x 4) + (3.14 x 3.14))
Z = 5.08
pf = R / Z
pf = 0.78
All on the assumption of 50Hz supply!!!!!!!
maybe im missing something butXL = 2 x 3.14 x 50 x (10 x 10-3)
XL = 3.14 ohms
is 31.4 ohms
Don't put in the 10 in the 10-3, that might be where you're going wrong.
10 x 10-3 = 0.01 10 to the power minus 3 (or 10 / 1000)
so try 2 x 3.14 x 50 x 0.01
that comes out as 3.14 ohms
(i know its a bad pic, had to cover the flash or it just blinded everything)
I prefer a Caseo over the Sharpe - especially if it can't calculate properly............
