Hi All,
See this thing:
http://uk.rs-online.com/web/p/din-rail-panel-mount-power-supplies/0468308/
If i mounted it in an IP rated metal enclosure would it overheat?? I have never used one before. so have no idea if it gets hot or not.. In the datasheet thing for it. it says ouput 120W. but max input 170w.. Does this means that at max output it gives out 50watts of heat??
Would a little cooling fan be any good?? [The IP rating of the enclosure does not matter really, i just wanted a decent metal box to stick it in!!]
john..
See this thing:
john..
