power to pond
paul b b
May 26, 2009
1,751
stuck between a firm pair of t***
hello chaps,
customer wants power to a pond for pump etc.... any advice or things to look out for?
she also wants th power supply carried on to a gazebo (light and socket) can i do this from the same supply or is it another run?
thanks
You could take feed into a waterproof socket and then onto another socket at gazebo and then into spur for light. For the small current needed a 13 amp spur would be adequate.
thanks batty, so your saying to run the pump off a socket? i have not done one before so have no idea how they get there power. thanks
also, could i spur off a socket in the house or do i need to put a new feed in?
Would go for 12v pond pump - if pump leaks whilst it is turned off, then pond can be 'live' without tripping RCD and as ponds are insulated with plastic/rubber it doesn't short out until someone sticks hand in water whilst standing on earth :( . I understand this has killed people. Other than that armoured cable or syflex is good. If controls are to go near pond, mounting on a pole about a foot above ground level is always a good idea to prevent water/ insect life ingress. and generally try to avoid damage by spades and lawnmowers :D
Smiths do a water proof socket with external switch, so you don't have to keep opening / closing flap to turn pump on and off. Don't ask me where to get one, you'll have to do internet search.
like this?
I made it linky
:D
What about getting an electric eel? :coat
But thats what the RCD is for is it not?
thanks guys,can i spur off a socket in the house though? or do i need a new feed from cu?
You could, but if there was a fault on the outside bit it would take the ring out. A dedicated circuit would be better IMO, but if not possible you could spur.
