Is It Meant To Burn
- Feb 4, 2011
- 9
- 0
Hello to all,
Can you advise me on the following.
I need to supply power to a shed which is only 10 feet from my property.
The shed will house a tumble dryer & a light.
The CU is at the other end of the house and not easily accessible.
Can i tap into a double switch socket directly across from the shed inside the house using an RCD spur.
The socket is on the first floor and therefore an overhead to shed option would be preferred.
I assume i need a CU in the shed.
Also which type of cable is needed ie SWA, Earthing etc
I have added some pics as suggested also the socket I suggested spurring from is on the ring.
This post has no link to an other postings.
Any and all replies appreciated.
