- Oct 22, 2010
- 14,651
- 1,211
Manator...many people think of me and then slap ME! I have that effect on people!........ :coat
I always use twin brown saves using that nasty sleeving.Personally I don't use the term "3 plate"I just say "loop at light" "loop at switch" or "Spider"
My preference is for loop at switch, much easier when you get "fancy" light fittings and of course for those wretched downlighters.
What happened to 2 core & earth with 2 red cores for the switch drop from "loop at the light" I've never seen the modern equivalent with 2 brown cores?
Kerchy ...the phrase " Clutching at straws" springs to mind.... :coatJust had my first ever brainwave, well I think it was a brainwave.....three wires [mains in, mains out, out to light] = 3switch plate = PLATE....ipso facto 3 PLATE...well it's a thought. albeit a carp thought... :coat
Dave,Personally I don't use the term "3 plate"I just say "loop at light" "loop at switch" or "Spider"
I used it by mistake once, never used it since prefer to use sleeving.Dave,Brown/Brown in common use down here in civilisation , don't use it myself anymore due to cost and mistakenly using it for feeds TBH.![]()
You forgot the stick of Pyro compound in your pocket too, in winter. Ahhhh !! The memories ...the vile stink of rancid tallow ...until the adoption of the Pipe Fitter's threading compound in tins .Oh how I remember the days, fault finding was a nightmare. It was also around the time when you could not run horizontal between accessories, sooooo UP across and down OR DOWN across and up so you could have almost 5m cable between two sockets that were only a metre apart! FFS you even had to put the length of cable on the Installation cert WTF! The 'good old days?' the only good thing was the apprenticeships! Beejayzus I learned some stuuf in them days. Improving IR on Pyro with a piece of string, fishing [now barred by the Sontarans or somebody] down cavities by saving the lead sheath on lead twin cable, keeping green sleeve in your 4r$e pocket in winter so it was always soft, making grommets out of T&E sheathing...must go now as my carers are due in to bath me.......... :coat
I remember keeping Pyro compound in my pocket and getting a row from my journey man, when I took it out and it was covered in swarf must have been from cutting and dressing cable tray. Do you still get Trefolex for conduit threading, I did like the smell of Trefolex, but I also liked the smell of cutting and filing Tufnel and that will probably result in an early grave.You forgot the stick of Pyro compound in your pocket too, in winter. Ahhhh !! The memories ...the vile stink of rancid tallow ...until the adoption of the Pipe Fitter's threading compound in tins .
I last used Trefolex about 10 years before you in 1988 when I worked for the Electricity Board.When did you last use Trefolex Roy? I did at college back in 1998 when doing My 2360.
