Anyone had any problems with Protek RCDs?
I got called out to a job last week, TT supply, Protek RCD consumer unit and RCD had tripped and would not reset, did the usual tests and everything Ok but still would not reset.
I removed the RCD and drove home with it to see if I had one in my garage, I didn't, so had a ring round and no-one had them in stock.I went back to the job and refitted the RCD and tried it one more time, and this time it stayed on.
I tried the test button and it tripped, reset it no problem, checked it with RCD tester and everything fine.Plugged everything back in and turned appliances etc on, no trip.
Any ideas on this?, I put it down to either dust/grit inside RCD or I had released something inside with the vibration of removing it.
Then today I have wired a supply to a metal portacabin, TN-C-S supply at origin and I have TT'd the portacabin Ze of 0.26 ohm.Again a protek RCD consumer unit, RCD not tripping at all on X1 but tripping on X5 in 18.9 ms and 8.9ms, did a ramp test and tripping at 33mA.
