Riggy
I need to install underground cabling for a public address system at an Autograss track. Is it as simple as running 1.5mm2 2C SWA? I guess the longest run will be 100m.
I was about to say the same thing, most PA speaker configs we did were 100v systems wich were looped, dc would require a more consideration.Hi
How big is an Autograss track? Is the current system definitely loud enough etc? Are they using 100V lines and Transformers at each Horn speaker? If so then replacing current
with thick (same total CSA). SWA sounds OK over short distances. For small 100V systems there is a guide here http://www.thatcable.com/info/100v-Line-Public-Address-PA
(Note the 100V I'm talking about is the AC voltage of the audio sent down the line to a step down transformer at each speaker. I assume the 12V you mention means they run the amps off a car/ battery (Different thing))
If it is an 8 ohm non-transformer speaker system and not 100V you need very thick or multicore cable . . .
If they are hoping it will 'improve the sound' etc then a proper design + beefier system and proper approach will be needed:
The last time I was an expert on this it was for University 'House' systems in Bars and discos so I've no idea at all what regs might need to be met in a public stadium but for indoor sound systems in large student bars and discos etc we used thick multicore cabling with no CPC but half the cores as + and the other cores as - Again you need to ask them to specify what they need.
HTH
Wow!Hi
HTH
But then you lose the benefit of the Tx AND delay would you not,?
