probably cost an extra fewgenerally on newbuilds etc. I think it was a trial, obviously never caught on.
This is what annoys me, gas engineers can remove and refit meters, plumbers can remove and refit meters, sparks can;t even connect a set of tails into an existing meter.I am Gas Safe Registered, as long as you have done the meters course and passed you isolate and take the meter out so you can work safe while doing pipe-work etc, when your finished you pop it back in, nice and safe !!
You've hit the nail on the head.I'm tired of this debate, any DNO who would like to take me to court for working on a dead system that I have isolated via their cutout, due to their inability to come up with a workable process between them, the supply company's and our industry.I've always phone the DNO to let them know the seals were cut and why along with my company details and to date no one has said I should not have done this.
EDF will not fit isolators so it could take me two days to do a cu change and customer would be without electricity for that time. You are lucky if you have a good dno, EDF are not very helpful.Look guys, sorry to be the party pooper, however, none of you are legally allowed to pull the DNO fuse unless you are a DNO employee or other person authorised by the DNO in writing.If you do and something goes wrong you are in breach of EAWR89, and possibly ESQCR.
I'm sure the DNO guys on here will back me up.
I must be blessed as I can talk to sense to my local DNO and get things done, they are as far as I can see nothing but helpful regardless of metering supplier!
Has anyone been trained on live working on the national grid with current paperwork to authorise them to do this (DNO employees excluded!).
If you have not then you must not do this.
As I understand it, it can be made into a criminal offence, depending on what happens after you cut the seals, when you have no further control over the premises.
Abstraction comes to mind!
completely concur. There is no option in EDF territory. I have been taught to pull fuses by a metering contractor in EDF areas and no specialist PPE was required to do this (unless working with cast heads) so why a decent solution to this problem cannot be found is beyond me. It took me about 1hr to read the procedure and past the test, and that was to change the whole meter not just pull the fuse!EDF will not fit isolators so it could take me two days to do a cu change and customer would be without electricity for that time. You are lucky if you have a good dno, EDF are not very helpful.
ill answer this about the area i work in,Excellent post Sparkss.That's just the way it should be. But perhaps you can answer this scenario:
I find a BIG problem when the customer's electricity supplier is NOT their local DNO. In that case, if I phone the DNO (Scottish & southern in my case) for any request, as soon as they look up the address and see they are not the supplier, they say they can't do anything. They say I must phone the supplier who will then pass on their request. So I phone the supplier who usually turn out to be useless. N Power are the worst, they won't do ANYTHING by phone, even when I have tried to report a dangerous situation that needs immediate attention (where SSE would attend that same day if I called them) all they say is "put your request in writing and we will deal with it"
I think this situation is deplorable. It's certainly not in the interests of safety and no doubt leads to more sparky's doing things like pulling the main fuse and cutting the meter seals to fit new tails, and not being able to get someone to attend for an emergency the same day is downright dangerous.
Personally I think the DNO should attend to the request in the same was as if they were the supplier, after all it is they who will eventually attend when requested to do so by the supplier.
I'd be interested in your comments.
Yes I have, I have my HV authorised person ticket which allows me to work on the grid, switch high voltage, work in sub stations etc etc, unfortunatly I'm still not allowed to pull a 230v fuse, I am however allowed to switch 275Kv in a substation!! Make sanse of that!Has anyone been trained on live working on the national grid with current paperwork to authorise them to do this (DNO employees excluded!).
I would say it has somthing to do with cost if gas or water leak someone is paying but if it is a potentialy leathal situation then it costs them nothing? :|It does seem a daft situation where you would report a gas/water leak and the relevant people come out as soon as to fix the problem but contact the DNO to report a potentially lethal situation then they request it in writing and so on . It's not surprising that electricians do what they do without bothering the DNO's . :Blushing
