Hi
I will soon have 3 panels on a metal corrugated roof (outbuilding). They are on the ground, on plastic boxes at the moment. I plan to use the plastic boxes on a different install, and attach the panels directly to the metal roof with mini rails. From what I've read, it's a good idea to run a cable from the panels to the rod, due to possible build up of static in the roof, malfunction, shorting etc. I have installed the earth rod next to the outbuilding and run an earth cable to the hybrid all-in-one inverter/battery system via a consumer unit with a type B RCD.
So my questions are mainly related to the details of running the cable, plus anything I may done wrong in the install, if anything.
I used a 6mm (7m long) single core multistrand earth cable for the inverter and CU. Would it be ok to run a similar cable to the panels?
Should I cut the cable in 4 and add terminals to attach to the 3 panels and roof?
The method would be drilling the mini rails/roof, and use nut and bolt to attach cable terminals.
Would there be any corrosion; and how to minimize it? I think the rails and roof are aluminum (?), and the nuts & bolts steel (?)
I do not know the resistance of the earth rod, and cannot think of a cheap way to measure it. Is this a must? If so, any suggestions?
Should I proceed with the roof install without knowing this info?
If I use the renusol plastic boxes on a different, flatter, roof (on a different offgrid system), do I need to earth those panels to a rod as well? The panels would not be touching the metal roof, though the PV cables will likely touch the roof at some point.
I am a DIYer (and new to electrical stuff until last year!). I have been reading some forum posts and found that a couple of people have a very similar system to mine: binky and Ucathmydrift ('RCD tripping problem' thread). I'd love to hear from you, and I have a few more question relating to the AC input of the hybrid inverter (which is not connected at the moment), but will leave that for another thread.
I think that's all. Thanks in advance!
Offgrid System specs:
3 x Panels:
Peak power 410W
Vmpp 31.25V
Voc 37.25V
Impp 13.12A
Isc 13.88A
Iconica Hybrid 3000W 24V pure sine wave inverter
6 x 100Ah AGM deep cycle
3 x Panels:
Peak power 410W
Vmpp 31.25V
Voc 37.25V
Impp 13.12A
Isc 13.88A
