- Nov 30, 2008
- 929
- 54
is there a maximum length of hose you can have on a bathroom extractor fan?
what the difference between axial fans and centrifugal fans please?It's about 3m for an axial fan, but can be longer for centrifugal ones...If you have a long run you'd be better off using some 4" soil pipe and a bit of flexi at each end to connect up.
thankyouIn simple terms Axial fans are low pressure/volume, while centrifugal fans have higher pressure/volume rates. This means that centrifugal fans are used where you might have longer ducting runs or need a higher volume of air rto be moved.
If you have to go 4m then I go for an in line centrifugal fan..I've just put a Vent Axia one in and it is very quiet!!
the fan (4") cost me
like this but cheaperI got it from a local independent wholesaler..It was just a standard inline model and didn't come with any duct or grills![]()
Monkey,Take a good look at that kit I pointed you to. I believe it will satisfy your requirements all in one box! And only
what were they?i install it upside down by mounting it to the rafters rather than joists. This has the added benefit of decoupling the fan from the ceiling somewhat and reducing transmission of the motor noise.Good idea
i've identified other, better 'engineered', methods of avoiding condensation problems.
o right. theres not any isulation up there just some gravel looking stuff so might go for the ducting.From my first replyon't forget to lay insulation over your ducting to keep condensation down. Or use insulated ducting:
http://www.screwfix.com/search.do;js...h_search=90765
