avinalarf
- Jun 2, 2008
- 415
- 0
Just been to look at a job...
A variety of switches need moving, due to doors having been moved, segregating light circuits and adding a new switch for utility area.
TNC-S installation. The CU was an old MEM with an external 63A Newlec main switch. There was NO RCD protection . Earthing was 16mm and tails were 25mm.
Anyway, apart from moving switches, I may need to upgrade the supply to the shed as it's been done in T&E :_| and the client said that when they attempted to switch on the pond pump, everything went off
They will also need a new circuit to provide for an electric cooker.
Personally, I feel that they should have a new CU. I just wanted to know at what stage this would be deemed "absolutely necessary" - if at all.
N
N
