's ok if you wired it and not just testing itPersonally I would pull a cpc through it and not rely on the conduit
you need to stop doing PIR's. you obviously dont know what your doing. just because its in steel conduit doesnt mean its dangerousExactly and if I was testing it would fail
AGREED.you need to stop doing PIR's. you obviously dont know what your doing. just because its in steel conduit doesnt mean its dangerous
I like that:^OApplaud SmileyApplaud SmileyApplaud SmileyIm sorry if I keep banging on,but it makes you wonder sometimes if someone like that has actually ever seen a galv conduit job.
I do some factory work for a large multi national company that works 24/7/365 and the conduit is as new(bit dirty/dusty perhaps but mechanically sound),
so it is never an issue as to the continuity.
its all down to having a little piece of paper thats says you are qualified to fry someone,
or having the experience to know how NOT to.
Where in my post do i say its dangerous ?you need to stop doing PIR's. you obviously dont know what your doing. just because its in steel conduit doesnt mean its dangerous
I guess probably assumed because you said you would fail it..Where in my post do i say its dangerous ?
AND...The problem is that years ago it was totally acceptable to use the conduit as a cpc.Since then there has been some serious implications on the suitability.
However this is only shown on testing, you can not fail an installation unless there is shown in the tests that the circuit protective core is now at risk.
you said it was dangerous when you said you would fail it.Where in my post do i say its dangerous ? Every conduit installation that I have done as a seperate cpc installed and in many case such has hospitals it is specified.Conduits are often installed in areas where they are not accessable and therefore not open to inspection.
I have come across conduit installations where the impedance changes with the weather. So when carrying a PIR and the conduit is embedded or I am not able to inspect it throughout its run I always recommend a cpc is installed.
Oh and incidently I do know what I am doing andyc
